Rear Cargo Box for FJ Cruiser
Texas TT
Top of the box, drawer faces, and drawer sides are constructed from solid hardwood (oak) flooring. It has 2 coats of polyurethane. Sides are cedar 2x6s. The balance is plywood and some painted metal. Plywood inside is stained and sealed.
Drawer slides are 24 inch full length open. Handles are recessed stainless with some tie downs on top.
3 main drawers that open to the back. A full width 'secret' compartment that opens to the top on a piano hinge.
This is a lower profile system, about 7 inches. Since the top is made from flooring, it can take some weight. I have put about 400 lbs on top before and it held up fine.
Some wear and tear from being used, but overall it is in good shape. Most of the time it had a heavy rubber mat on the top. I just replaced the slides on the large drawer. New handles all around as well.
I am not a carpenter, but quite a bit of time went into it. The materials alone would run $200-$300.
Is bulky and weighs about 50 lbs, so local pickup (DFW area) only.
Asking $100
iStan814
