Rear Clunk noise 3rd Gen
Dawnofmorning
Alright so I've exhausted my attempt to search online for info on the rear clunking/thud noise that's been driving me crazy.
So it's been happening since I've gotten it back in July (05 LTD). Since then I've replaced struts, springs, upper control arms and ball joints (front and rear) and sway bar links. I've removed the spare tire, removed the rear interior (finishing putting down noico).
It happens when going over really any kind of bump or crack in the road. It's definitely coming from the rear. Checked underneath and not seeing anything jumping out at me as being the obvious cause.
Before I take it to my mechanic I was wondering if anyone had any ideas as to what it might be. I know it's hard to diagnose a random noise but any help is appreciated.
Check your rear differential mounts.
Clean the bushings, and examine them carefully.
Sounds like you've sourced it to the rear end...but the engine mounts are possibly shot as well. Likely to be an issue if the rig has seen many off-highway miles. (Mine were completely broken in half...not too bad of a job to replace.)
Cheers
mbobhat
