Rear differential center
cherokeekid
I've searched everywhere I can think of: do the rear 9" and 9.5" share the same center section? I.e. 12 bolts to the housing?
Is there another way to visually determine which one? The dealer was not able to confirm.
plh
I have both sitting in my garage, I'll snap a photo at some point, won't be tonight.
cherokeekid
You mean shaft spline ? Can a 9.5 have 31 spline or 28? I'm looking at a 2000 sport (need the r&p) I know it's 4.90. But it's a 3.0 I can't remember the spline for sure but I think 31. The best I can tell the center looks the same as the 9.5 I have (12 bolt) mounting the chunk to the housing
ChargerX3
As far as I know it only comes in one configuration. The shaft is slightly larger so it should become apparent that it won't fit.
cherokeekid
Not worried about the carrier or shafts. Just the ring gear diameter. From what I can tell 9" had 10 bolts and 9.5" had 12 bolts mounting then center section to the housing, but want to confirm before I rip it out
plh
Sorry for the delay, both the centers in my garage are 9.5" ring gear (one is a locker, the other isn't) - forgot about that. I'll need to take a look under the '93 at some point.
cherokeekid
Thanks
The number of bolts for the center work, I've heard 10 for the 9" but want to make sure before I crawl under and yank it out
Can anyone confirm the bolt count?
