Rear disc brake conversion kit?
kellymoe
Is there anyone who sells a rear disc brake conversion kit for the Defender here in the US? I lost my brakes coming out of the White Mountains last year:Wow1: no fun. Also looking for a domestic X-brake company or at least someone who imports it. I have looked around but so far no dice.
Oh wait, Keith............doesnt he sell a kit for the conversion?
Rovertrader
Supporting Sponsor
check with Keith, or substitute a D-I rear axle as they are plentiful, inexpensive, and easily up to the task
kellymoe
The rear axle on my 130 is a Salisbury rear end with coils that are much larger, wider, extra HD coils. I had a D1 up until last year in addition to my 130, it was pretty amazing how much larger the 130 coils were compared to even the D1 extra HD coils. I have a email into Keith, he does some fine work and has helped me out in the past hopefully he can point me in the right direction.
BTW some nice looking trucks you have sold there at The Rover Barn.
Antichrist
I'm assuming you read this thread:
http://www.pirate4x4.com/forum/showthread.php?t=137412
and this one:
http://www.aulro.com/afvb/technical-chatter/50181-salisbury-disc-brake-conversion.html
You'll need two of these
http://www.lrseries.com/shop/product/listing/14700/2985/9/FTC3306-HD-REAR-AXLE-CALIPER-MOUNTING.html
Ah! I knew I'd seen an actual step by step somewhere!
I'd seen it several years ago, and found it again linked from the aulro thread.
http://forums.lr4x4.com/index.php?showtopic=11685
Maryland 110
Kevin,
Switching the rear springs for an axle swap is as simple as unbolting the lower spring cup off of the axles and bolting the larger on. Takes 5 mins with an impact. I recently swapped a salisbury out for a rrc lwb rear axle. Very straight forward swap if you don't have any bolts rusted to the inner metal sleeve in the bushings. Keith was offering the rrc rear machined brackets the rest of the stuff you can pick up on discoweb from the usual suspects cheaply enough.
My 130 has inner and outer rear coils-yours has a single spring ?
Rovertrader
Supporting Sponsor
As Doug said, simply change the bottom perch. Also, do a little research and ask Keith, but my $$ would be to do the swap to D-I axle and upgrade shafts to Keith's, and I believe the strength over the Sals is tremendous, makes upgrades to lockers cheap and easy. Always many ways to skin a cat, but look at the whole picture- both planned and unplanned.
Also, thanks for the kind words- loved my 130, and it had the inner/outer spring setup on a Rover axle, aka D-I -the factory setup at the time.
kellymoe
You assume way to much from me. It's been well over a year since I have been on Pirate.
Thanks those are great links.
and this one:
LandyAndy
Justin at Luck8 carries the XEng gear... see him for an X-Brake.
kellymoe
I looked through Lucky8's website last night because I saw that they carried them but didn't find it on their website, it's a little cluttered and difficult to navigate, I'll give him a call.
mongosd2
Here's the part number for the caliper mounting bracket: FTC3306, you can get a pair of them from Craddocks.com in the UK for the price of ONE here from the usual suspects...
The only thing is that the mounting the bracket needs to be machined down about .120 to fit the disco or rrc calipers...
We just did this...
R_Lefebvre
Always call him. He can get just about anything, it's not all on the website by any stretch.
Antichrist
Yeah, that's what I linked to, only from lrseries.
We just did this...
Interesting, the guy who did it here, http://forums.lr4x4.com/index.php?showtopic=11685 actually added a spacer. But maybe he was using different calipers. I haven't gone back and read it in detail again.
