Rear locker woes. :(
JamesW
I had the same issue today and I'm just in the house from fixing it. I put a vice grip on the hose before the diff, and turned on the pump, if it keeps pumping you know it is a leak between the pump and vice grip.
My locker was put in by me, so I have soft lines the whole way from the pump to the diff, and it had got chaffed through where it was rubbing the chassis, so I cut and joined it. Moving the clamp along the pipe helped me pinpoint where the break was.
jeep-N-montero
A very good tip, sounds better than unhooking the line and spending more time under there than needed in freezing weather.
Goldenbora
