Rear OME 2764's
TexasTJ
Climbing Nerd
Who is running 2764's on the rear of their Discovery 1's. I have 110 coils right now and she sits level and I'm trying to pick up the rear a bit. I don't want to mess up my daily ride at the same time. I running Bilstein 5100 too.
ZG
Busy Fly Fishing
You have front 110 coils on your front, or front 110 coils on the rear? What are the color codes? Rear 110 coils won't fit a d1
TexasTJ
Climbing Nerd
I was told 110 Coils by the PO I assumed that was all around. The could just be in the front to support the TDi I have 245x75's on the truck too.
ZG
Busy Fly Fishing
Probably on the front. What are the colors on the rear springs? 110 rear coils are a good bit larger in diameter, so they'd probably fall off the spring perches
Nonimouse
Cynical old bastard
Yup 110 rears are 7" in diameter not 6" so will not fit. OE 110 fronts are either progressive 155-215 lbs/inch or are 225 lbs/inch the former are the same as standard Disco 1 rears and will be yellow/yellow or white/white
Heavy duty OE 90 rears will fit and are progressive 210-240 they are green/yellow/red
Heavy duty Disco 1 units are Pink/Yellow/Red and are progressive at 200 to 330
I swapped from the Disco Heavy duty units to 764's (240lbs/inch and plus 40mm. I used Gwyn Lewis spacers on the HD units to make up the clearance for 245/75's on zero offset modular's. The spacers are 6mm circular plates. The OE HD spring gives about plus 25mm so I upped that with 4 spacers. Howvere the HD springs are simply too hard when loaded. I destroyed the bushes on the GAZ cellular shocks (not very good) in 500 miles and then lunched the shocks in 2k....
I swapped over to the 764's with 12mm of spacers and they are excellent. The biggest drawback is that due to the thinner, better quality wire in the coil, there is more upward movement in the spring before it becomes coil bound (the HD units become coil bound before they hit the bump stop) so I was hitting the wheel arch. A quick Camel cut sorted that.
At the time I was unaware the new Devo-Tech springs from Devon 4x4 are made by Eibach. they are £50 cheaper than the 764's - additionally since OME no longer get their products made in Australia, but in China, the coating quality has gone down hill. King Springs used to make OME springs; and Monroe made the shocks (with SuperPro bushes) - all very good quality control. Eibach are made in Europe. The coating is far better quality and lasts longer. I am waiting to see if the steel on the OME springs is still as good
Clemtiger84
