SAR Jeepster
Its time to upgrade my axles to accommodate larger tires and heaver gear loads for longer duration trips. I had a Dana 44 from a 75 Jeep Wagoneer in the front. This axle has a strong housing with 2 3/4”, 3/8”wall tubes. I chose to rebuild this axle adding 4.88 gears, ARB Locker, Yukon Chrome-Moly Axle shafts, Mad 4 Wheel Drive Axle seals, new ball joints and a Solid Axle Differential Cover. I changed the 7/16 wheel studs to 9/16 to match the new rear axle.
On the rear I had a Dana 44 from 89 Jeep Wagoneer. This axle had 2 3/4”, 1/4” wall tubes and a single small bearing to support the heavy end of my Jeep. This axle has bent on me before and I was able to straiten it and add a truss between the spring perches. This lasted a few more years but was like putting a Band-Aid on a broken arm. This axle bent again between the spring perches and the wheel so its time to remove and scrap this axle and replace it with a new stronger one.
I wanted to find an axle that I wouldn’t have worry about the extra weight of all of the gear on longer expeditions or pulling trailers off-road. A full floating axle has the benefit of 2 bearings to support the weight and the axle shaft only transforms rotation not having to support any weight. My current axles were 6 on 5 ½” and I have 3 sets of rims so staying with that bolt pattern and increasing the lug bolts diameter made more sense.
