Rebuilt 1989 Coleman Colorado. Austin Texas $2500.00
TexasTJ
Climbing Nerd
I need to sell my 1989 Coleman Colorado POP up.
I rebuilt this trailer from the frame up last spring. Wife wants a boat so the pup's got to go.
The floor and all sides are new quality wood (not particle board) and painted in mystic paint witch is is a non-toxic, ultra low odor paint that provides the durability and coverage you expect from a premium paint without the off-gassing VOC's and cancer-causing toxins that emit years after drying. Stronger, safer, smarter paint®. Now that's a breath of fresh air.(from web site). The Floor has fo vinyl wood and is coated with HERCULINER Truck Bed Liner on the underside to keep out water. I added a High Lift Slide-n-lock tie down system for cargo management last fall. It has a Pull out Full size bed and the table folds down to make a twin. The chair padding is all new with a 4" memory foam mattress on the full size bed. I have also reworked the suspension from the original Slipper Springs to a Spring over Axle set up with a rear shackles. I have put a lot of hard work into this trailer, but my wife wants a boat for the summer so it needs to go. $2500.00 . The Top is brand new from Bear Creek Canvas. The Tent is manufactured out of 10.38-once canvas which meets or exceeds industry standards. Whenever possible we use materials made in the U.S.A. Our windows are made of tinted 12-mil. vinyl to help keep out excess sunlight and heat. The screen on the windows is a tight 18x16-mesh assisting you in keeping out unwanted insects. A durable 13-once vinyl material over the bed wing that assists you in making sure your camping trip is dry and enjoyable.
$2500.00 OBO
545278_3919171452036_521424822_n.jpg166012_3919172332058_1195242722_n.jpg527147_4027695525070_1381359157_n.jpg
TexasTJ
Climbing Nerd
Bumping this back up. I have also reworked the suspension from the original Slipper Springs to a Spring over Axle set up with a rear shackles. I have put alot of hard work into this trailer, but my wife wants a boat for the summer so it needs to go. $2500.00
Mykol74
I'm in the Austin area but wish I had the $2k+ to drop for this. Good luck selling it, looks like you did some top-notch work when restoring it.
basicfish
Coleman Colorado is sold
I bought the Coleman Colorado from Texas TJ about a month ago, He did pull it with his Jeep JK, a TJ should pull it, I have pulled it with my Subaru Crosstrek
Basicfish
