Are these for starter or house side? Take a look at your current group size to match.
For start batteries, Interstate is a solid choice, compare CCA and get the highest rated one you can find in a reputable quality battery. Often a deep cycle/start/marine battery will have a better build and be able to better handle extreme conditions and demands of cranking over a diesel.
For house side I’d recommend an AGM(absorbed glass mat), the largest one that’ll fit with the biggest AH(amp hour) rating.
Look for these quality USA made options-
Lifeline
Deka/East Penn-
Batteries Plus carries these as a rebranded Duracell. Also a good place to find a starting batt, and with locations everywhere, easier to warrantee any issues.
Just don’t want to mismatch new with old if you’ve got 2 or more batteries on either side, starting or house, replace at the same time.
