Recommended Rover shop in San Diego??
Hey guys,
Looking for a rover mechanic in San Diego, hopeful near La Jolla.
got one ended up being a very expensive oil change at my regular shop in the Bay area before I drove down for work in San Diego for a couple of weeks. I've never had an oil leak in the several years that I've owned my LR3 and noticed a drip at the hotel parking lot. And the skid plates are covered in oil.
Was hoping to find a shop to just pull off the skid plates and double-check that the drain plug was reinstalled properly.
Thanks
SDDiver5
BBC Automotive. No experience with them but I used to drive past them all the time going to a dive shop near them. Long time beaches community mechanic. Red reviews before going there obviously.
It's in between LJ and PB on a street that parallels the freeway.
Good luck
Blaise
You know it's just 10x 13mm hex bolts to pull the skid plate right? No jack needed either, just put it in off-road height. 13mm for the drain plug also. Might save you some time and $ :)
If the drain plug is tight check the oil filter as well.
Houie
