Recommended Winch Size for Gen 2 Montero
rajin cajun
In the near future I want to put a winch on my Monty. I've decided to go with a Warn Winch; however I used a couple formulas with 1.5 times the weight and 2 times the weight. Every situation is unique in itself.
So far, I'm considering the 10,000 vs 12,000. I've read the archives in the 4x4wire and will go with synthetic rope [Master Pull]. Looking for suggestions. Thanks in advance............
Happy Trails.
cap510
I seen cheap 8k and 10k failure under extreme conditions, I got a 12k E-milemarker on mine and have used once on my self but several times on other rigs even a semi at one point with no complaints.
off-roader
just out of curiosity, any way to mount a winch on the stock front bumper (gen 2)?
Mount it to a plate mounted between the frame rails and tucked in nicely out of the way. Then route the winch line out through the bumper and fairlead.
The bumper itself is not strong enough to support a winch mounted directly to it without integrating additional re-enforcements.
iStan814
