Redarc Fixed Monocrystalline Solar Panel
Doc Fluty
I have the Redarc Redvision system and Manager 30 system for my truck. And how my head works, since I want to get into solar, I looked into a Redarc product to pair with them.
My question is, price aside, is the REDARC 200W Monocrystalline Solar Panel (SMSP1200) a good one? It fits almost exactly the area I have to work (47"x43") with and appears like the highest wattage I can fit there... but it says it's limited to 10 amps.
If you have any thoughts on it I would appreciate it. I will probably buy a solar blanket to pair along with it if it doesn't fulfill my power needs... but at least I have something up there as I drive full time.
thank you.
For reference: https://redarcelectronics.com/products/200w-monocrystalline-solar-panel
it's 20v and 10amp at max power. You'd want an MPPT charger to get full use out of it, otherwise I'd look elsewhere.
The specs say it has a MPPT solar regulator, so it should be good.
I'm not an expert by any means. Check with Redarc to be sure.
$2.75/watt is expensive, even at 20% efficiency--but if it fits, maybe that's the best choice!
You can also look at a pair of 100w panels to fit your roof--many of those are around $1/watt...
Jlbeats
