RedArc Manager 30 help
mep1811
Gentleman Adventurer
I am getting a error message that my battery is under temperature -40 degrees.
The only thing I can think of is the controller was exposed to high humidity for a few days but never wet.
Is there a fix? I've disconnected the power but no change. Thanks in advance.
emulous74
Reach out to Redarc, they are really good at responding. If I remember correctly the original Redarc BMS30 was issued in the US under the Australian spec BMS30 and there were problems with low temperature issues, Redarc now has a specific North America version for the BMS30. I believe they were able to provide a fix to the early customers.
wicked1
That specific temperature issue they had was just a few degrees off.. Was preventing lipo's from charging when it was still just above freezing.
-40 is likely the lowest it will display.. So, something is broken. Or possibly disconnected.. Be sure the temperature sensor negative terminal thing is plugged in to the controller.
wicked1
I really like the redarc, but am afraid of it failing.. It's an all eggs in one basket situation. Where as people w/ a separate DC/DC for alternator, separate solar, and separate shore charging devices can still find another option if one of the three things dies.
mep1811
Nothing has changed with the wiring nor is is -40 here in West Texas. I have a message into Redarc.
mep1811
A valid point
dhuss
