Removing bulkhead/enlarging pass through on box van
danjr
Anyone ever done this? I have a small pass through right now with a bump out for the driver seat, but the passenger seat is all but unusable due to the bulkhead wall. I'd also prefer to remove it to allow for swivel seats, etc.
The cab has around a 1.5" flange that mates to the Box wall with several rivets. If I were to cut out the entire wall (driver and passenger sides), following the flange with an addition 1-1.5" of box wall left inside the flange, would there be any structural issues to be concerned about? Would I need to put in a frame around the new cut out?
Really wanting to remove this wall as it will greatly expand our living space and comfort, just trying to understand what I'm getting into before hacking away.
Thanks for all the knowledge sharing!
Oh yeah, build thread to come...
515051
515052515053515054
Jo_Duval
I only removed a partition in my regular Savana it was in with a combination of bolts and rivets.
I don’t think it would be hard or any structural.
Good luck
eporter
Just follow this guy’s lead and you’ll be all set.
E350 10ft Box Van
I called and talked with Supreme Mfg. about this. Make the cut out about 3" smaller from the center of the thru/cab bolts. No additional support is necessary, the support from the cab is sufficient. You can find the edge molding on eBay or amazon. Good luck!
eporter
I’d say the ambo box has a lot more rigidity and strength than a box truck box..! Like 100x?! Probably need to leave some flange to support the cab to box connection and bolts when the structure isn’t as robust.
danjr
Thanks to all! Hacking begins today or tomorrow. You guys are awesome. @Burlydirtyhippy especially, thanks for the separate correspondence!
Nice weather has arrived. Trying to move as quickly as possible to get this baby out and exploring. Build thread to come.
Linesman1776
