Removing Four Wheel Camper Furnace
kingb
I'm trying to remove my 2003 FWC furnace for replacement, and was hoping that the whole thing would just slide out the back. However, it is attached somewhere in there.
Has anyone removed a FWC furnace? Can you advise on how to get it out of there?
Many thanks!
On my 79 Grandby, the exhaust installed from the outside and slipped over a pipe on the heater. I think proper procedure would be to remove the exhaust from the outside, then the heater itself from the inside. That said, my exhaust pipe was rusted to the heater, and I couldn't separate the two. Had to destroy both pieces to remove it.
kingb
Thanks! Here is how I ended up getting it out:
- disconnect the propane
- remove the plywood panel from the camper interior (aside from the screws on the outside of the panel, need to remove screws from L-shaped brackets on the part toward the front of the truck)
- then remove the 2 screws that attach the bottom of the furnace to the camper
- slide the furnace out to the inside of the camper
project13support
