removing front seats on LR3
krick3tt
I have seat covers that I have yet to install (Wet Okali). Is there a video that would show me either how to install them or how to remove the seats to install them so I don't improperly preform the task and really screw something up?
DiscoDavis
Fairly straightforward, there are plugs for the electrical components and keep track of the bolts and where they go. I did it without watching anything.
The only problem you might encounter is potentially on your outboard side seat adjust switch housings. It is possible if there are side cinch straps on your covers to rip these wires out. You can see the wires if you pull the cover out a tad.....my cover is obviously not on at the moment! You can see the cinch straps for the M&M covers which I am sure your covers have as well.
This is what the wiring looks like with no covers installed. The driver's side is near identical with the exception the lumbar switch for my LR3 SE.
Hope this helps!
