MobileAndMonitoring
Hello Expo,
We decided to go full time in our 2005 Toyota Tundra 3 months ago and have been on the road since. We've had 3 months of using our electrical system on the truck 24/7 and are considering upgrading our 4 year old AGM house battery to lithium (LifePO4) rather than replacing the AGM. According to the battery monitor we average around 65ah draws but we do draw about 100ah a couple times a month so I think we could use more capacity. Also the battery is getting old and I'm assuming it doesn't have the capacity that it used to have. And finally with winter coming I know the solar will not be producing what it is now. Anyways I thought I'd draw up a basic diagram of my electrical system with only the charging portion shown to simplify the diagram below. The LifePO4 battery we are considering is the Aims Power 200ah LifePO4 battery. It's a group 4D just like what we have now so as far as dimensions go it will be a drop in replacement. Haven't seen much online about them but thinking of taking the leap. Specs are here.
So the main thing I'm trying to understand is what I need to change to my on board charging system. Our Victron Energy solar controller supports lithium batteries but I assume our alternator does not? After some basic internet reading it seems we need a DC to DC charger aka battery to battery charger? (On a separate note I wonder if we should have had one this whole time for our AGM). Is this true? If so there seem to be a few offerings out there. A couple concerns I have below:
-The alternator seems to never get above 13.5-13.8v. Does this fact alone require a DC to DC charger because the voltage is too low (battery requires 14.4-14.6)?
-We have 2 gauge wire between the staring battery and house battery. It seems most DC to DC chargers do not support such large wire
-I presume the National Luna Battery Isoloator will not be an issue? Would this DC to DC charger go between the battery isolator and house battery?
-We also have a AC to DC charger we hardly ever use (haven't used it since we left our house). Would we wire this behind the DC to DC charger as well?
-Are below freezing temperatures an issue? How about extreme hot temps? Battery warmer or cooler needed?
-How to determine what amp draw would be suitable? We have a large overpowered alternator and would like to know how you might calculate which one to choose.
Any help in this would be awesome. We have 2 weeks coming up next week in Portland and I think I can get most of this done if I can fully understand what goes along with these new Lithium batteries.
