Replaceable shock mount sources?
1x1_Speed_Craig
I need to make some lower shock mounts for my M101A3 trailer, for which I've swapped in a standard 3500-lb. trailer axle. I have a couple Chevy shock mounts similar to the attached photo, but the stud diameter (OD) is too small for the military shocks. The shocks have what appears to be a 3/4" diameter. I'm not sure what other applications use a shock eye this big, but the military shocks are in great condition, and I'd like to retain them.
Can anyone recommend a source for removable shock mounts in varying sizes?
Thanks,
Craig
elmo_4_vt
The last set of shocks I bought (Bilsteins) came with a couple sets of inserts that could be put in the shock eye to different size studs. I'd look into that first. I know you can by different size collars at Lowes/Depot but I'm not sure I understand what your exact requirements are.
1x1_Speed_Craig
Great idea, elmo. I already talked with my buddy at Napa, and just have to get some dimensions to work with. New bushings with a smaller hole or a sleeve/insert would both be viable options.
Thank you!
Craig
flipstick
