replaced two front air struts, still getting suspension fault. What now?
So my front two air struts both had leaks in them and I had the normal height only fault code. I replaced the two struts today, had no error codes for about a half hour of driving it. then when I started the truck up later to go to dinner, and the suspension fault light came on again when I got in the parking lot. So do I still have a leak? or is my compressor going bad? (while replacing the air struts I did take apart the valve block and clean it up and reinstalled it).
A.J.M
When the system refilled with air. Did you get any warnings about compressor overheating or such?
A healthy compressor will refill with no issues. Just let the car idle while the compressor does it's thing.
A worn one, will throw up overheat issues etc on the dash.
Clemtiger84
