Replacing a port on a Dometic hard wire kit
donmontalvo
Sanity check. :)
I have a Dometic hard wire kit that I run up to my iKamper roof top tent, it has a 15A fuse:
https://www.dometic.com/en-us/outdoor/food-and-beverage/coolers/accessories/dometic-hwk-dc-222471
I want to replace the two-pin port with one of these, which comes with a 10A fuse:
Is this a good idea? Or should I worry about the amps and/or fuse?
Here's the overlanding power kit I had installed a few weeks ago:
https://donmontalvo.com/2022/03/09/main-line-overland-lifepo4-******/
Any feedback appreciated!
donmontalvo
Bit the bullet, it works fine. I had to shave a bit off of the Dometic plastic holes to make them round.
Works like a charm, looks accurate on voltage, though I'll rely on the Renogy monitoring.
This Dometic hard wire kit will be pulled through the rear passenger window, and into the iKamper at night.
dhuss
