Hi, everyone,
First post; been lurking for a few weeks. I recently bought a 1985 VW Westfalia automatic with 212,000 miles on the chassis and about 50,000 miles on a Subaru EJ25D engine. I’m excited about doing some mods and upgrades and the first thing I want to do is install a solar system and auxiliary battery. I’ve been reading all the helpful threads about solar, ACRs, Inverter/Chargers, etc. Thanks to all!
I think I’ve figured out my electrical system but I wanted to run it by you guys before I buy anything. I want to have an auxiliary battery that can be charged by solar, shore power, or alternator power. I’ll be camping on weekends mostly without shore power, I will not be using the camper as my daily driver, and when it is stored it will be in full sun. Note that I cannot provide shore power when it is stored.
Using a web based usage estimator, I calculated my usage at roughly 150Ah per day with the biggest draws being a Propex HS2000 furnace and an Engel MT80 fridge/freezer along with lights, fans, electronics charging, etc. I’ve read however that these estimators can be off significantly.
I’m still trying to figure out which batteries I want to use. I’m set on AGM and I’d like to have about 300 Ah. I want to put the battery or batteries under the bench seat in the rear of the camper so space is limited. I was thinking about a VMAX 350 Ah but then I read a bad review. Now I’m thinking about 2 Universal UB121000 batteries wired in parallel which would only give me 200 Ah but are more well regarded. I’m looking for suggestions on the batteries.
I’m tying Engine Battery (Eng+/-) and House Battery (Hse+/-) together with a Blue Sea ACR 7610. I read instructions somewhere on attaching the ACR to the starter instead of the Engine Battery to reduce cable length so I will try this although I don’t know how this will apply to the Subaru’s electrical system. I’m fuzzy on where Subaru ends and VW begins in regards to the electrical.
I’m planning on using a Xantrex Freedom XC Inverter Charger with Control Panel not only to supply 120v when on battery power but also to charge batteries when on shore power. I’m also planning on using a Victron 100/20 managing 2 @ 175W Newpowa solar panels connected to House Battery.
I can't get my crappy ascii drawing to display properly so I'm attaching it to this message.
Please let me know if I’m missing anything or anything seems amiss.
Thanks!
Will
Thanks!
Will
