Roof rack wiring
mav204
I just installed a Gobi Rack on my JKU, need to run electrical wiring to back up
Lights in the rear, just want to see how people are running the wiring from inside the jeep up to the rack.
emkay
from a gap between windshield and wiper cowl to the plastic cap under the front tubing of the gobi
Sent via my bongo drums...
mav204
I need to run the wiring up the rear supports. Thanks for the advice for the front
m(a)ce
you can run them inside the rack tubing for a clean look.
there are grommets on the rack that you can remove & fish your wires to the front.
if you're planning to tilt the rack you'll want to add waterproof quick disconnect plugs.
delivered by winged monkeys
Topo.Ranger
I want to run the Gobi Rack also! So i will be subscribing to this thread to get some ideas. I did buy the DELPHI WEATHERPACK KIT for my DIY sPod system so I may use the extras on the roof rack.
