One pair of new shackles for sale. Ideal as high-end recovery points. These are magnetically inspected before being sold to the public. They are used in lifting and crane operations and are rated 5000lbs for lifting, but actual breaking strength is 25,000lbs. These are unlike typical shackles in that they rotate in the direction of the pull, whether up, down or off to side, etc. This is the same ring that Safari Guard put on their bumpers but with a different coating.
100% USA made. From the mounting surface, they are 4.78" long and 3.25" wide. Bolt is 1.5" sticking out I believe. Shackle bar is 3/4" D
Fully rotates 360, and up and down 180. Black oxide finish but should be powder-coated (but not the bushing surfaces) or painted if they are going to be exposed to weather. Sell for much higher new, but I will sell them for $135 with free shipping the lower 48. Comes with two shackles and two plastic retainer clips to keep the rings from banging around when not in use.
