RTT On a 2000 Chevy Tahoe?
cvanhook
Hey Just Curious if anyone has ever mounted a RTT on a chevy Tahoe and if so, what additional roof rack cross bars you used. Any info is appreciated!
Thanks,
Chad
CrazyDrei
Space Monkey
Cvanhook,
I can't help you with the RTT and having a Suburban or a Tahoe makes an RTT kinda redundant and a useless and unnecessary weight on the roof, but that's just my two cents.
I can help you out with a bomber root rack that will support the RTT and anything else you want to put up there.
https://www.expeditionportal.com/fo...ow-lift-with-37-s.166120/page-21#post-2428914
This is the roof rack I built nearly five years ago and it has been nothing but solid even on a 10,000 mile trip to Alaska and back with 800-1,000lbs on the roof so it would support a RTT with no problems whats so ever.
Good luck!
E.J. Webb
I've ran a 23 Zero 6x8 RTT on the factory cross bars but it bounces around a little bit. I upgraded to a Rhino Rack that's 4.5X7 with custom mounts now. There is a difference between the Z71 and LT racks. Witch model are you running.
cvanhook
I have a Z-71 the plan is to run the tent on the Tahoe until I get our trailer built and then the tent will go on it.
Thanks
cvanhook
Cvanhook,
Good luck!
Thanks for the info
E.J. Webb
It will be fine on the cross bars than, I also am going to build a small trailer for my RTT so I can put paddle boards on the roof rack.
dhuss
