If I get your right.... You want to drive a pre 07 diesel truck to an area that has low sulfer fuel?? I take it you are running an older diesel and want to make sure that running LSD wont hurt the engine? If that is the case, I run my old 1992 7.3L IDI diesel on the LSD BUT I also add a quart of TW-# 2 stroke oil directly into the fuel tank along with a quart of ATF fluid EVEry fuel fill up (30 gallons)
Been doing this to my old 7.3IDI for the last 8 years with NO issues.. It quiets the engine down AMAZINGLY!!!!! I think your good running LSD in ANY diesel that is newer than 2003, Pre 2003, I would recommend adding 2 stroke oil to the fuel tanks for the extra lubrication..
Just my $.02
I read it that he wants to take a truck with an ULSD motor to countries that do not sell it and is wondering what to do.
Absolutely will not make thru emissions testing if you have it in your area. Do you have it?thanks for the information - i'm new to the world of domestic diesels. If you remove the emissions items will the vehicle make it through yearly emissions testing?
Charlie
You are pretty much screwed, unless you want to restore the system to original each time you get it tested. You are either going to have to move, or register the truck elsewhere, or better yet sell it and buy a pre-emissions vehicle.I'm in Georgia and they have emissions testing
