Running 4-50w aux lights off of one relay
WagoneerSX4
Is it possible to run 4 - 50w hella 500FF driving lamps off of a single 40A relay? I'm finally getting around to redoing my harness and I'd like to simplify it by wiring all 4 together instead of 2 switches. I know I need 12 gauge wiring since (50x4)/12v=16.7A and 12 gauge of less than 50ft can handle 20A. I figure a 40A relay with a 30A fuse (or should I go 15A fuse since that's roughly 80% of the amps needed?), all 12 gauge wire except 14gauge going to the switch.
Does that make sense?
vicali
You could wire both relays from one switch- but having duplicate harnesses in there with smaller loads on lower gauge and smaller relays would be better/cooler/safer than running one harness with a big relay and heavy wiring.. What if you have a short?- or you decide to upgrade bulbs?
I run two separate harnesses with 10g+30A fuses, that way I can always upgrade to 100w bulbs in the future..
I like having two switches for my 4 500FFs, the centers are aimed down the road and the outsides are in the ditches.
WagoneerSX4
That was my main thought when making two harnesses at first (same as you - two aimed forward and two to the sides) but i've never used them separately. I was also thinking it would be easier to find an issue out in the middle of nowhere with less wiring/relays.
I don't think i have plans to upgrade to 100w. The 50w bulbs are more than adequate, especially with my 55w HID projectors in my headlights. I really only use the aux lights to get hot spots where I need them.
vicali
Or spare parts? lol, it's 50/50 really.
I run them this way for another reason as well, see here in BC you are allowed 2 additional driving lamps.. so having them separate means I can use one set on the highway legally.
WagoneerSX4
Haha, I'm not worried about that in Ontario. Our HTA says you're only allowed 4 forward facing white lights (even if they're not on). So basically any vehicle equipped with fog lights is already capped out for lights. Technically I need to drive around with opaque covers on my hellas for it to be legal. But every cop here knows it's a ridiculous law to hand out tickets for and it's only in place for idiots running around with 8 lights on their cars blinding on-coming traffic in cities. Not something they're looking out for.
But I leave the covers on anyways. I take them off before a trip where I know I'll be using them.
Pccruiser
Yes one relay is fine. Wire your lights in series down into the one relay controlled by one switch.
I = P/V
Amps = watts / volts
So at 50x4 watts your relay needs to be able to handle 16.67 so a single 40 is fine.
Exactly how I wired my 4 55 watt lights.
Don't forget to check your fuse though. Mine came with a 15 amp inline fuse that I needed to upgrade to 30 watt. Slow reaction fuse.
Sent from my SCH-I545 using Tapatalk
vicali
Lights in parallel, relay trigger and switch in series. :)
What gauge wire are you using?
20A-240W 10ft is 12g;
Pccruiser
Yup parallel and the switch is series. Silly me.
And I used 14 ga. But I only had about 5 feet worth. Maybe less.
evldave
Expedition Trophy Winner
Those wire ratings are the minimum wire size. For lights, which seem to be very susceptible to voltage variation, I always bump up one (sometimes 2) wire sizes. This helps prevent light flicker. I figure the cost is basically the same, so a little insurance on the wire size works well.
As a note, I run 12GA on my 500FFs.
iStan814
