I have 1997,, 147K it says collectors addition on it. I a little rust post right above the windshield, is there anything I can do myself to stop the rust.
when I had my windshield replaced, they found a rust spot. They had some chemical to treat the rust. I did not get the name, but your local shop should know it. If you can see the spot, after treatment, I would repaint the spot with the Duplicolor spray paint from auto parts stores to help keep moisture out of the area.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
