6912
what makes these trailers so indestructible is the convict shape of the panels the easy and fasted is using ploy resin and woven. when the resin shrinks and preloads the panels float in the angles glued a few cheap pop rivets after a week backfill any gap with can foam. epoxy is more toxic epoxy that was only $30/gal that a great deal.
Thanksgiving. Give all your friends freshly killed wild turkey as a present. you should see the deer herd .By using the fiberglass outside angle it has a rounded edge . we levy the flange off in the mold . Picture is a trail top a different way to build
