S-10 Crew Cab - Thunder II - GONE
HenryJ
2001 Chevrolet S-10 Crew Cab.
This truck is a one of a kind and ready to tackle anything from a drive across the country to the rigors of off road exploring. This is not the soccer moms truck that rolled off the assembly line. Just over 91k miles on the odometer , I am the original owner and builder.
The Crew Cab has undergone quite a few changes.
Roof rack
G1 Goodmark cowl induction hood
Skidz Cut-out Flares
Audiovox overhead video console
Trip computer
Homelink
Auto dim mirror
RCA aux. inputs
Pillar mounted dual gauge pod w/digital trans temp and aux. fuel gauge
Altimeter / Clinometer
Console PowerPort
WeatherTech WeatherFlectors
SofTopper canopy
Aluminum front, engine and transfer case shields, Steel gas tank shield
2" body lift
Boise Spring works 2" rear spring kit
Westin Signature series step bars
Front and rear tow hooks
BFGoodrich TAKO 33x9.50-15 tires
ZR5 wheels w/"Adventure" hub caps
Bilstein heavy duty shocks
Swing away spare tire carrier
Front hidden and rear 2" receiver hitches
21 gallon auxiliary fuel tank
Shaved badges
Front 1.25" spacers and rear 1" spacers
Steering Stabilizer
Energy suspension polyurethane sway bar bushings and custom quick disconnects
ZQ8 Quick ratio steering box
Re-valved power steering pump
Quadbeam Headlight Mod
55W fog light bulb upgrade
Aux. 100w fog lights
Spot back-up light
Auto dim review mirror
Bravada double visors
50w halogen back-up light bulb and back alarm
ZR2 8.625" G80 rear axle assembly
Moser Engineering Aluminum differential support cover
Hypertech's Power Programmer III
Large capacity replacement radiator
Auxillary "sandwich style" transmission cooler
Engine block heater
CFM throttle blade
1" throttle body spacer
K&N FIPK
3" catback with high flow muffler
Heater control valve
Taylor Spiro-pro plug wires
Dual ignition coils
MSD 6AL ignition control
LS1 Electric fans conversion
200 amp AD244 alternator
Air Cleaner Restriction Indicator
Jet Low Temp Stat
Corvette Servo
and much more...
Receipts for over $11k in upgrades as well as service records. This truck is well documented. Offroad/City mileage 14 mpg Highway 18 mpg on 10% ethanol (add 10% for ethanol free fuel)
This truck is equipped for light expedition travel. The family is growing and we need room to haul another motorcycle. Selling the truck to move to a larger vehicle.
More information: http://www.s-10crewcab.net/HenryJ/thunder2.html or visit http://www.s-10crewcab.net to learn more about the s-series crew cab trucks.
Located in Eastern Oregon. Ontario , Oregon. Delivery options negotiable. $10,000 will take it to a new home.
EDIT: Price cut to $8500 for a quick sale!
PM or email brule (dot) lehman (at) gmail (dot) com
HenryJ
I found a rig at a good price, if I can sell the crew cab. My loss is your gain.
Rock bottom priced at $8500 for a quick sale.
Houie
