School me on hand winches...
STAGE 2
...specifically the tirfors. I'm looking for a winch for my rig, and I don't want to go electrical for a variety of reasons (don't want a winch bumper, heavy, pricy, only 1, or at the most two locations). What I have decided on is a tirfors style winch. There are several models out there (black rat, ARB, grip hoist etc) and I'm trying to figure out which would be the best for a 4000 lb vehicle. Most have a 30 lb winch with a 3500 lb lift rating. The griphoist has a 4000lb lift rating. However there are 60 lb ones that have a 7700 lb lift rating.
I realize that normally, the pulling ratio isn't 1:1 i.e. you don't need 1000lbs of force to pull a 1000lb object. That said, friction, mud, and nother nature can be a bear so I'd like something that I could use without having to go the snatch block route, or worrying about exceeding the load on the winch or the cable.
With all that said, will the 3500/4000 winch be fine for my rig, or should I just go for the 7700 super heavy duty one and deal with the extra 30 lbs of weight?
STAGE 2
Why would this be better?
I don't know that its better, just simpler. One attachment point on the truck and one tree stump. Dont get me wrong, I do carry them. Its just easier to not rig it up, I will have more useable cable distance and the winching time will be shorter as well.
michaelgroves
There have been quite a few thread on this topic, some recently.
But my view is that there's not much benefit to having a big, heavy tirfor. At the end of the day, all the pulling is done by your arms!The additional mechanical advantage that gives the bigger hand-winch its higher pull rating is easily replicated by using some additional snatch blocks if necessary, and to suit the specific scenario.
Advantages to having a small, light, good quality hand winch (vs bigger):
  • Cheaper to buy
  • Easier to stow
  • Easier to handle and often quicker to rig
  • More rigging options offered by snatch blocks and rope
  • You probably need the extra rigging anyway
Disadvantages
  • Must buy and stow additional rigging
  • Might sometimes take longer to rig
STAGE 2
Correct me if I'm wrong, but the weight of the tirfor doens't have any effect on the force required to pull the object. I.E. its going to take X amount of grunt whether you have a 30 lb tirfor or a 50 lb one (assuming straight rigging).
  • Cheaper to buy
  • Easier to stow
Price is definately a factor. The heavier duty ones are almost twice the price. For me at least, easier to stow isn't really a factor with a 7' bed. I'm curious about the 4th factor however. How does a lighter duty winch have more rigging options? Regardless of the one I get I'm going to have a recovery kit with the same gear.
michaelgroves
Quite right. But of course, handling a 50lb lump of metal is a lot more effort than handling a 30lb one! You'll find that when using a hand winch, there is a lot of carrying and manoeuvring the winch and cable.
I was comparing, say, a 7000lb winch, versus a 2000lb winch with lots of snatch-blocks. You can rig the latter in many more useful ways than the former. Of course, you can use the former with snatch-blocks too, but then that does beg the question, why carry such a heavy duty lump?
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
Perhaps this link/thread may be helpful...
YaRiteZ71
