What are you looking for?
The 22R-E is the same from 1985 to 1988. The 1988 will have a W56, same behind all 22R-E engines. The 1988 will have a W56-B, BTW. The '88 will have the same top shift transfer case as all 22R trucks before 1989. The IFS is the same from 1986 through 1995, basically. I have control (A-arms) arms parts from a 1987 on my 1991.
If I was shopping for an IFS truck I would look at a couple of things. First, do a once over on the engine and drivetrain like you would with any truck. You want 125 psi or more compression in each cylinder, ideally 135+ and +/- no more than about 5~10 psi at the most. The shifter seat will be loose (the stick will feel wobbly). If so, that's more or less normal, if not then it's possible the guy is very good about maintenance.
Check the ball joints, tie rod ends and idler arm for abnormal wear. Most likely the idler arm and ball joints will be worn and that's not particularly unusual. Look on the frame near the idler, if there are wear marks, scratches, etc., or if the idler is loose, then the the steering will need some attention. If you want to quick check that the frame is straight, measure the distance between the lower, rear A-arm mounts. These are the big gusseted mounts coming straight down from the frame where the suspension is bolted. It should be very close to 17" from inside-to-inside. If it's more than 17.25" then it's possible the truck has been abused or jumped
Mostly the same stuff that applies to 1979-1985 trucks applies, the only difference is the IFS itself. The front diff on an IFS truck is a 7.5" ring gear and does have a slightly higher rate of failure. So spin the half shafts, open the fill plug, make sure it's smooth. In a stock truck it's extremely unlikely that the front diff will be a problem, though. Also make sure the CV joints aren't clicky and are smooth. You can tell a lot just turning them by hand with the hubs unlocked, but be sure to engage 4WD and check them on dirt.
The main things different from a solid axle truck you need to give a once over:
idler arm (right side frame, opposite of the steering box)
CV axles
ball joints
lower rear control arm mounts
TREs
