Security
Steve Curren
Does anyone here know the best way to install a cut off switch or kill switch on a TJ? I have heard about a number of Jeeps stolen in the Phoenix area and I know of a man locally who had his locks punched as well as the ignition but thankfully it was not taken.
madizell
I used to have a Jacobs "Stop Thief" device, which allowed the vehicle to start and run for 30 or so seconds before stalling the engine. Attempted restarts were possible the first time (as a safety for the real owner - the stall would be a warning to find and hit the switch) and the engine would run for about 10 seconds. After that the more you tried to crank the engine, the longer it would take before the system would reset. Because the device was tied to the electronic ignition, the only way to defeat it was to remove it entirely and reinstate the original ignition. I believe there are other manufacturers of similar devices. The switch was a micro switch easily hidden in the location of your choice, and it had a valet position so you could temporarily override it without telling the parking attendant where the switch was located, or that it even had a theft device on board.
Alarms are rarely effective. A stop thief is very effective because it permits the vehicle to be moved, but only a short distance, and it is not tied to the ignition switch, but the ignition itself. Moving a vehicle raises the offense to GTA, a felony in most states.
Steve Curren
Sounds like something I might like to see, where can I see it online I tried Jacobs and found nothing maybe you have a site I could check out?
Thanks a million
Photog
My first 4Runner had a kill switch to the fuel pump. The stainless steel switch, was mounted in the floor, on the passenger side of the engine tunnel. It was mounted under the carpet. Only the little switch lever stuck through the back of the carpet. It was not easy to see, even when you were looking right at it. The engine still cranked (providing false hope), and it would actually run for a few seconds on the first crank.
805gregg
I had a Ravelco anti theft devise installed in my Liberty prior to a 2 week trip to Baja last summer. It's a little expensive $399 but they have installed 3 mil and had no thefts, great piece of mind in a foreign country.
Fifthpro
I was looking at installing a Trunk Monkey but found the Barney Anti Theft Device to be quite effective.......often times I find the would be thief laying next to my vehicle dead from laughing to death or from the sheer terror of being shot with a sling shot!
Steve Curren
Thanks to all of you, I think I have decided upon a system. I will have to pass on Barney becasue I have seen him shoot..:gunt:
madizell
Thanks a million
I checked with Jacobs. They discontinued the product 3 or 4 years ago. Hope the product you chose works out for you.
GMc.
Lawrence
86cj said:
This is probably the best option out there. I bought one from Frank a couple years ago and he modified it per my specs without hesitation. He took great care in designing and perfecting this system and did it for a good cause. Now, ORO is carrying the kit and per Frank's request, a portion of the profits from this product will be donated to the Marine Corps Toys for Tots program each year. Can't beat that.
Houie
