MGSlynch
Overland Compact Kitchen System
The Overland Compact Kitchen System puts together all the needs you’ll need for your Overland or camping experience. This is our smaller unit to allow to be utilized in smaller cars or SUVs. Custom made from the ground up featuring our Red Oak wood finish made from the highest grade plywood...
Overland Premium Kitchen System
The Overland Premium Kitchen System puts together all the needs you’ll need for your Overland or camping experience. Custom made from the ground up featuring our Cherry wood finish made from the highest grade plywood. Turn the cargo space of your truck or SUV into a spacious counter-top for all...
Discount code: ExpedPort
The Overland Premium Kitchen System puts together all the needs you’ll need for your Overland or camping experience. Custom made from the ground up featuring our Cherry wood finish made from the highest grade plywood. Turn the cargo space of your truck or SUV into a spacious counter-top for all your kitchen and storage needs! Easy to setup and collapse. The Premium includes the whole Overland Kitchen and the following accessories: slide-out cutting board, removable sink, bottle opener, pantry, water jug, stainless steel grille spatula, and utensil storage. We’ve went through a handful of prototypes to provide you the best quality drawer system made from 3/4 inch exterior premium plywood with three coats of exterior urethane. We’ve reinforced each outside corner with aluminum. This is a very solid and rugged box that will withstand the test of time when properly cared for. You will not be disappointed in the craftsmanship we put into our product.
Dimensions: 24” high x 21 3/4” deep x 31 1/2” wide. Fully extended: 53 1/2” deep. 1/2 extended: 37 1/2” deep. Weight: 97 lbs
Drawer system is not waterproof and should avoid any moisture. This is a wooden box made from mostly natural materials.
We’ll provide the you the details for installation upon purchase. Mounting can be easily down with our installed hinges on the sides.
The Overland Compact Kitchen System puts together all the needs you’ll need for your Overland or camping experience. This is our smaller unit to allow to be utilized in smaller cars or SUVs. Custom made from the ground up featuring our Red Oak wood finish made from the highest grade plywood. Turn the cargo space of your truck, car, or SUV into a spacious counter-top for all your kitchen and storage needs! Easy to setup and collapse. The Compact includes the whole Overland Kitchen and the following accessories: slide-out cutting board, removable sink, bottle opener, pantry, Coleman Triton cooktop stove, water jug, stainless steel grille spatula, and utensil storage. We’ve went through a handful of prototypes to provide you the best quality drawer system made from 3/4 inch exterior premium plywood with three coats of exterior urethane. We’ve reinforced each outside corner with aluminum. This is a very solid and rugged box that will withstand the test of time when properly cared for. You will not be disappointed in the craftsmanship we put into our product.
Dimensions: 20 1/2” high x 18” deep x 25 1/2” wide. Fully extended: 46” deep. 1/2 extended: 37 1/2” deep. Weight: 47 lbs
Let me know if you have any questions.
