Series IIA Swing out door
atlcruiser
Sort of a cool project here.
1972 Series IIA original owner gave it to the son who is now mid 40s...(so am I :))
The goal was to not use a drop down gate, to have a swing out door. to have the spare tire on the rear securely, no rear bumper could be added and he also wanted a removable bike rack on the tire and he wanted it to look as original as possible, even down to the paintwork!
We measured and cut the rear door down. We got a Mantec swing out carrier and a new set of hinges. We fitted the door and had to remove the cap on the PS rear corner to mount the carrier. Once the carrier was on straight we had to make sure the door would fit then we drilled the upper hinge mount and used the lower original hinge mount. I opens like butter!
To top it off we took a section of door cap from one of our parts series trucks that had the same sort of age and carefully fitted it onto the top of the cut down door secured with a few tack welds cleaned up with galvanizing paint.
The Thule bike rack pops on/off in about a minute.
Overall a pretty sweet mod that greatly increases the usability of the back end of the truck.
Willie B series IIA-1087 by ULC rovers, on Flickr
Willie B series IIA-1355 by ULC rovers, on Flickr
Willie B series IIA-1369 by ULC rovers, on Flickr
Willie B series IIA-1370 by ULC rovers, on Flickr
Willie B series IIA-1376 by ULC rovers, on Flickr
Willie B series IIA-1449 by ULC rovers, on Flickr
Willie B series IIA-1450 by ULC rovers, on Flickr
I Leak Oil
That rear door is more cleanly done than most I've seen. I've always wanted to make a hinge that allows the tailgate to function as a drop down or swing out. There are times that I could use both.
atlcruiser
Thanks!
That cage came on the truck from unknown sources. We are making our own version now but the ctr cross beam is a bit different.
ukoffroad
I did the same thing to my 68. I did not need a tailgate, but an easier way for the kids to get into the back. My tire is still on the hood.
dhuss
