Martinjmpr
Wiffleball Batter
(Xposted from Tahoe/Yukon forum since this one appears to be a bit more active.)
I want to call on the GMT-800 Mafia here on ExPo for a possible/potential 4wd issue on my Suburban.
We got a late spring snow here on the Front Range of Colorado. Got almost a foot of heavy wet slushy snow here at my house.
On Saturday the wife wanted to look at furniture so we took the Suburban (2004 1500 LT, 4x4, about 156,000 miles on it.) Since it was intermittently snowy and slushy I put the truck into "auto 4wd." Drove all day like that until the end of the day when we were coming home through a mountain canyon with snow building up on the road, I went ahead and put it in "4 Hi" for about 2 miles so I would have sure traction. As soon as I got to the main highway it went back into Auto 4wd.
Sunday morning driving to get gas I switched it from Auto 4wd to 2 hi (all the snow was gone and the roads were dry by that time) and shortly after that I got the "service 4wd" message. I cleared it with the steering wheel button and it did not come back on. After filling up with gas, sitting in the parking lot, I decided to run the transfer case through all modes except N (I sometimes forget that there's a neutral on these!) It went into Auto 4wd, then 4hi, then 4 lo (with a noticeable "clunk" shifting to low) and then back to 2 hi. No problems, no warning messages and no indications that something wasn't right.
Is this something I need to worry about? Is there something I should be checking? I didn't really test out the 4wd, just made sure the dashboard buttons worked, and they worked fine.
If I understand there are 3 potential points of failure in the 4wd system: The button on the dash, the encoder motor on the T-case and the fork on the front axle that engages the axle to the wheel. Is that correct? And if so, are there specific symptoms for failure of each component? I have heard of the dashboard button going "haywire" and not working correctly (as in, showing the vehicle is in 4 low when it is not in 4 low, showing neutral when the vehicle is able to move, etc.) As I understand it, that usually is fixed by replacing the dashboard button. For other failures, I'm not sure what the symptoms are.
Thanks in advance! I may be doing some mild 4 wheeling this coming weekend so I want to make sure the 4wd system is operating correctly.
