Shotts' 1997 Lexus "Rock Crawler" buildup:
ShottsCruisers
The forums are cool. On one thread we've got DesertDude building a tricked-out 1997 with all the trimmings (more like what I've done with my 2001 100-series). We need to watch his build. :coffee:
On this thread, I'm building the LX into an aggressive machine, similar to my 1993 Cruiser. We're being aggressive on everything except tires. There, I opted for BFG AT KO's for their good handling and quieter ride. (If I regret this I'll MT KM the thing, though the AT's on the 100 have taken a huge beating and never failed. We'll see!) I want to keep a good ride so this whole Lexus pruchase doesn't fail me. The goal is to build a truck I like to drive so I can leave my 100 at home MUCH more.
Here's my first round of pictures. For now I'll just point out what suspension lift is used since the rest is in the works:
Here's what was ruled out:
Slee 4 and 6" lifts...this was due to the fact they have 25% more spring rate over OME J-springs. Since this will be an unloaded truck, the stiffness would be way over the top.
Here's what's happening:
OME-based lift for a 5-inch total lift. This will allow the LX to remain garaged. At this height unless other mods are completed the truck will drive poorly. I have added whatever it takes to maintain the LX's good ride. It will be completed in two stages.
STAGE 1: (COMPLETED)
OME 850J/863J springs
OME L-series shocks
OME Steering Damper
Slee caster correction plates
Slee sway bar drop brackets
Slee front dual CV driveshaft
Custom rear bump-stops
Custom lower rear control arm skid plates
STAGE 2:
After installation of both custom steel bumpers and the Slee rock sliders the truck will then be loaded. We'll take measurements, then add:
OME trim packs F&R to level truck to 5-inches lift (up as high as 6" on front if needed to level)
Slee front and rear panhard rod adjusts (to re-center the axles)
After the above, if needed, due to vibration issues, we'll add upper rear control arm extensions and/or a rear CV driveshaft.
Alignment
At this point the lift will be complete! 5-inches and ready to rock! :ar15:
Here's the pictures/buildup:
http://shottscruisers.smugmug.com/Vehicle Specs and Modifications/125374
blupaddler
Conspirator
John
Looks good so far!!! It's nice to know that the Slee 4" are heavier than the J's.
So what stage is the snorkle? That wasn't mentioned, but it's already on. ;)
Keep up the good work.
Scott Brady
Founder
I like it John. Sweet ride amigo :clapsmile
I cannot believe no one makes a 5" spring at the factory rates. I would seriously consider talking to a custom spring house.
ShottsCruisers
Me too! I would KILL for J-height and stock rate. KILL! :(
blupaddler
Conspirator
John,
At what stage do you get rid of the CHROME rims?
I do really like the Lexus rims, maybe just powder coat them black. That way you'll be like a top-secret prototype or something. All blacked out and cool lookin' in that AZ sun. :p
Oh, nice pics on your website. Not to detract too far. But, your buddy Walt with the green 80...He has the 5" lift? Is that the J's or Slee combo, and is he running 33" tires still. I like the look of that with the extra clearance. :wavey:
brittan
Do you still have the stock springs? Let me see what I can do...
I have a set off my 97 LC if you want them. I just put on an OME medium setup. I like it and will move to the J's when it becomes mine to wheel with. I never took the LC out with the stock springs so I can't tell you how they did offroad. I can tell you the OME's are stiffer, but still flexy.
I am keeping an eye on John's build...believe me...
Are you locked John? After taking mine out sliders and lockers are next on my list. I also have a set of 35" MTR's that will show up in the garage soon off a buddy's 4Runner. Damn...I got to get Darcy anothe car.
ShottsCruisers
blupaddler said:
John,
I'm researching rims now. I'd like alloy OEM rims though with 5-inches lift I'm concerned about safety (though possibly for nothing. I'm researching.)
Walt's 80 is SWEET. And yes, with 33's it always looks like he flexes better. We've discussed that on the trail. He recently added J's for the extra lift.
ShottsCruisers
Not locked. I chose a dry climate mobile without lockers over a locked one from snow, wet, etc. I also never touched dirt. It's no biggie adding ARB's because I gotta pay to have everything ripped out to regear. So, lockers/gears are last. I stole this truck lockers or not. :D
Signed,
Got Lucky
ShottsCruisers
brittan said:
Damn...I got to get Darcy another car.
Negotiate with Darcy! :luxhello:
Set up a weekend luv affair with her at a nice resort. (Great deals this time of year)
Make :Wow1: at her all weekend. Get her a pedicure at the resort.
Then, Sunday evening tell her your desires (ANOTHER CAR SILLY :hehe: ) and ask for her partnership.
I'll bet J-springs are on order SOON! :clapsmile
Jonny Adventures
