outofrshell
After reading the feature article Essentials:Recovery Gear it got me to thinking that I had the means to make an aluminum handle for my shovel. I had found a piece of aluminum tubing about 8ft long X 1.5 OD X 1.0 ID and had been looking for a use for it. After cutting it to about 3ft which makes the shovel short enough to fit across inside my Trooper if I need to (like security). I made the taper by machining steps down to 1" and then smoothed it up with a file ( I don't have a taper attachment) and then fastened it the same as a wood handle with 2 rivets thru the socket of the shovel. I think this will be stout enough that if needed it could be used for other uses like a cheater pipe,pry bar or self defense against mad squirrels and such.
Dave
Dave
