Slide in non cabover camper box 800$obo
Juanblzer
Here is my late 70s/80s camper project. I rebuilt a lot of this camper and sealed up the broken plastic skylight and some other corner leaks with quality plywood and sealer. I added aluminized sheet insulation inside the walls. The interior of the skylight shows the aluminized material. I never got around to making a panel to cover it. All side windows are slatted frank type. The door has slide windows. All screens are intact. The floor sits on new plywood and in a steel cradle I welded up.
It’s roof is sealed with 3m marine seal and elastomeric roof paint. I never finished all the interior because I wanted to use it. It could easily be completed. The exterior is coated with raptor liner and can be painted over.
As-is I used this camper as a gearbox and place to sleep 2 adults and my 9 and 5 yr old. It sure Beats sleeping on the ground or sleeping in a tent.
It has a custom outdoor outlet and indoor outlet setup so you can have shore power.
Uses:
Finish interior and minor finishing touches.
Great as-is as camper
Use it for storage
Use it for in-law sleepovers
Hunting cabin
Playhouse. Kid cave
Lovers hideaway
Opium den
Moonshine still
Grow room for hydroponics
Doghouse
Dimensions
Fits 8ft long “long bed trucks”and requires 48.25 inches between wheel wells of truck bed. It could easily be bolted onto a flatbed trailer or utility trailer.
I can help load it and I have camper jacks
800 obo
Houie
