Slik 700 DX Pro Tripod with Slik SBH 280E Ball Head
amocaT
Used but in great condition. $150. Pasadena or
Tripod info:
Using a "Tri-Titanium" aerospace alloy compromised of aluminum, magnesium, and titanium, the Slik 700DX Pro Tripod Legs has a strength-to-weight ratio 40% greater than comparable tripods in its class. It is a very professional unit whether you're concerned with strength, fit and finish, or refinement of operation. The rapid-type center column cannot rotate accidentally, and the lever locks work securely with a minimum of movement. The 700DX has foam-padded upper segments to ease carrying on your shoulder and working in the cold, and its simple angled rubber leg tips give a firm footing while also allowing you to carry it upon some aircraft.
A professional's legset with 30.2mm maximum diameter upper segments
Dual alignment grooves on all leg segments eliminate leg twist and increase strength
Individual 3-position leg angle locks for low angle work or use on uneven terrain
Rubber leg tips for maximum traction outdoors, protect indoor surfaces, and allow you to carry the tripod upon a commercial aircraft (many airlines prohibit spiked tripods of any length)
Working height of 70.1" puts camera's viewfinder at or above eye level for most users
Two-part center column allows lower minimum operating height
Ball Head info:
The Slik SBH-280E Professional Ballhead with Quick Release is made from finely machined and carefully anodized hardened aluminum parts that are designed to give many years of trouble-free smooth operation.
SBH series ballheads feature an easy to use, single knob operation to lock or release the ball connected to the camera plate. The knob is oversized and has a well-textured surface for a sure grip in any condition.
Panning bed with degree markings
Bubble levels mounted on dual axis make accurate leveling of the camera easy
20mm diameter ball diameter
flipstick
