Doctor BeBop
I am selling a professionally rebuilt SM465 4 speed transmission and NP205 transfer case. They were both rebuilt by a 4x4 offroad shop transmission rebuilder with 40+ years experience in Arizona for his own truck. Neither has been used. The transmission has been upgraded with a sleeved 4th gear to address that weakness. It also has an Offroad Design 32 spline short main output shaft (see http://offroaddesign.com/catalog/sm465shortshaft.htm for details), and larger bearings installed. All bearings, seals, and gaskets are new, not cleaned old ones. The transmission comes with a custom made steel (not the usual aluminum) JEDS adapter to adapt the short output shaft to the NP205 transfer case. The NP205 transfer case is the newer round pattern and has also been completely rebuilt with new bearings, seals, and gaskets. It has billet steel endcaps, 32 spline input, 32 spline front and rear outputs with a flange on the front output. It comes with an Offroad Design twin stick shifter. I am asking $2,000 FIRM for everything described. I am selling both together and am not interested in any trades at this time. I also have two U bolt plates, four U bolts with nuts and washers and two top plates off of a 1987 one ton Chevy pickup 4x4 14 bolt axle, all good shape, $50 for all. Thanks, Eric
