Small evap leak detected
the davis
My 02 Montero keeps throwing the small evap leak code (0442). I have changed gas cap with mitsubishi cap, replaced gas tank and seals due to a recall. The dealer recently ran a smoke test and can't find a leak, this test has been run four times. The purge valve has also been replaced and I am still getting the code. Is there a way to bypass the sensor or does anyone have any other ideas about what might be causing the error? Thanks for the help!
XRoToR
This happened to me. Eventually I traced it to corroded vent lines from the fuel spout assembly under a plastic guard on in the rear passenger side wheel well. The parts were expensive but I was able to hack saw off the corroded line sections and replace them with rubber smog hose and I have had no more problems. I guess the rock guard in the wheel well traps all this wet slime and silt and the over time corrodes the steel lines.
seth.c96
