SMITTYBILT OFFROAD COMPACT AIR SYSTEM / 10 LB CO2 TANK
dcraig
I have 2 Smittybilt 10 pound CO2 tanks, both with regulator, quick-connect fittings, 25’ coil hose and carry case (everything they come with brand new.) If you've never used a CO2, you'll fall in love. These things are sweeeet. No comparison to an air compressor. They retail for $300 (plus tax.)
One tank is brand new and unused, never been filled. Asking $240 ($60 off, more once you factor in the sales tax savings.)
The other tank is used. The valve/handle leaks when it is opened, although it still flows through the hose fine. My guess is it is the O-ring but I haven’t had time to replace it. Powertank sells a replacement valve with O-ring for $40 (not sure if it fits or not), or you can probably get one from your local shop/store. (Or maybe you can just replace the O-ring.) Asking $175. ($125 off.)
Must pick up locally in Houston Galleria / Memorial City area.
Please PM me if interested.
dcraig
UPDATE: I ordered a brand new valve assembly. I would like $200 for the tank including the new valve assembly.
dhuss
