Snatch block for synthetic line
Metcalf
36,000 pounds safe working limit not mbs
What are you rigging for, Motorhome sized rig?
If the SWL you are looking for is 36K and the ring is MBS is over 100K......and you want to use a 3:1 FOS......
It is ballpark in the range you wanted, That was my point.
This stuff is generally rated 5-6:1 for SWL because it is coming from overhead lifting/rigging applications.
In my opinion, that is just getting to point of being silly overkill for off road recovery.
The do make a 2" version, but I haven't been able to get my hands on one.
WSS
Rock Stacker
Light, compact and very well made.
Ragnarok Overland
I would love to learn to tie knots like that. I assume it is some type of monkey fist.
Most soft shackles use a button knot, and there are various ways to terminate the "tails". They are very difficult to tie, and certainly take practice. As well, once you have built a soft shackle, it really needs to be tensioned, that's pretty easy to do, you can do it with a high lift jack, or just wrap a limb saver on a tree, hook your winch to it via the shackle, and put some tension on it, don't go nuts, but a good a out of tension and leave it there for a few minutes.
Houie
