Age makes no difference if they are stored properly, as directed above.
They will, however, age with use. Every time you stretch the nylon, it doesn't return back to its original length. It will retain some stretch memory. How many times you can use it and still retain as much efficiency as possible will be determined by how hard its been used. Given the relatively inexpensive cost of a strap, I would replace them every 5 years if its seen use a few times per year.
... Given the relatively inexpensive cost of a strap, I would replace them every 5 years if its seen use a few times per year.
I would be interested to see if some of the industrial suppliers of rigging gear have protocol of gear test/inspection or replacement.
^^^^^^^ plug for this guy. Does good work. I have used a couple of rope shackles I got from him last year MANY more times than I thought I would..and they work great.
Great stuff. :beer:
