SoCal (Redondo Beach): ActionVan Lifted 2WD1996 E150 Van Drop Floor $6500
KYC
Update: 06/09/2020
Ok so I got it oil changed, smogged and it is ready to sell. I am asking $6500.
I am now including a goal zero yet 1400w battery bank hooked up to a 150w solar panel.
Selling because I'm moving to a place with very limited parking.
For Sale 1996 E150 Drop Floor conversion van. 351w V8.
Portofino Blue (premium baby blue) Not Light Blue.
It was a handicap accessible conversion so there is an extra 6" of room in the middle of the van.
The van is well insulated with felt walls.
I removed the wheel chair lift and used it as a camper van for a couple of years. It will come with the ARB large awning, and the bedframe that was installed. It holds a queen size futon with the bottom part a little cut off.
The van has removable curtains, but I would recommend keeping them on.
There is an ActionVan Performance Suspension/Lift on it.
Some recent work:
New fuel pump.
Timing chain and cover gasket.
Rebuilt front hubs, rotors, brakes.
New Red Head steering gear box.
New cooling hoses.
New PCV hoses.
Swivel chair for passenger.
I am including some extras.
Obviously the battery bank 1400w
Inflatable X-Jack
Privacy Shelter x 2, a foldable one and one with a structure like a tent.
PETT toilet system
Queen Futon
Front Runner water tank 13 gallon
Foldable ladder
ARB large awning with walls and extra pole.
1 set of rud 4x4 snow chains (unused).
Action packer filled with a bunch of mercon 5 tranny fluid and everything for another oil change. 6 quarts of motorcraft 5w30 synthetic blend and filter.
Front runner table attached to rear door, it came loose, so it needs to be reinforced.
The van needs a little work, but overall in good shape. No major accidents, but the rear driver door might need fixing. Roof has surface rust. Passenger side door hand stopped working a couple of weeks ago. Probably a hook/spring somewhere came loose.
The van has been worked on by South Bay Car Care. The shop works on Sportsmobiles.
Oil changes with Motorcraft 5w30 synthetic every 3000-5000 miles. Installed Transmission pan with a drain plug, so been replacing tranny fluid also.
It has the E4OD tranny.
It has General Grabbers with the Spare.
About 130,000 miles.
Serious inquiries only and please contact me only if you are ready to buy.
I might be forgetting some stuff, so if you have any other questions, let me know.
DanoWall
