Solar guru needed
barny
I was already to order a 100 watt panel to go with my two 45 watt panels for my fridge setup and got to reading that mixing different watt panels should not be done. So now I am confused please help 12v system I know they need to be in parallel, morningstar prostar 15.
45 watts specs (x 2) - (100 watts specs
Maximum Power Voltage (Vpm): 18.3 Volt - ( 17.40 volts
Maximum Power Current (Ipm): 2.52 Amp - (5.75 amps
Open Circuit Voltage (Voc): 22.2 Volt - (21.60 volts
Short Circuit Current (Isc): 2.69 Amp - (6.32 amps
lcsodiver
As long as the output voltages are the same mixing different wattages should be fine. I have a 100 watt folding hard panel that I chain with my Brunton 26 watt soft panel to a charge controller that takes it to the batteries.... now you can run into problems if you try to run separate charge controllers for each panel depending on the controllers.
wirenut
Your specs. are close enough. Hook all 3 in parallel and it will work fine. You will need a fuse in series with each panel before they are combined for safety.
iStan814
