K9LTW
SOLD - DELETE - Whether I get the new Grenadier or not, it’s time to pay off some bills, and make some space in the garage for the next project. So up for sale she goes. She’s never failed to get us where we want to go, and I wouldn’t hesitate to do a repeat of last year’s VA to CO trip, again, right now. Get it now with nearly new tires with less than 3,000 miles!
Purchased in Sept. 2020 from the original family with about 250k miles, it sits at 271,518 right this second. Those miles will go up, albeit infrequently. If it’s sitting here…I’m going to use it!
I realize this will take a different kind of buyer, due to our unique use case. We go everywhere with our dogs…no kids. So I chucked the middle and rear rows when I brought it home. Ripped the interior apart and applied foil-backed and soft foam sound deadening everywhere save for the roof. I then replaced the carpeting with a vinyl floor. I definitely cut some areas short, so it’s not perfect, but it serves its purpose! I then built a flat from from the center console all the way back to securely bolt down our dogs’ crates, and attach a drawer, fridge slide, and storage. It can be converted back, but the buyer would be responsible for sourcing the seats they want, and second row seatbelts. If you’re a dog family like us, the crates can convey as well for the right price.
Frame is completely solid. I took pics and tried to wipe it off in places, but…well…she’s dirty under there. I will get its annual lanolin wax application done soon. There’s no body rust either. It’s currently kept in an insulated and dehumidified garage and I’ve never driven on salted roads. There are places of surface rust on the rear bumper and sliders from gravel impacts, and general usage. I plan to clean things up as much as I can prior to any sale…but they’re used.
Also…while it has a sunroof, it’s pretty much sealed shut from the Rhino Lining process. Given it’s covered by the roof rack, and we never use it anyway, it’s not an issue for us. I’m sure I’ve forgotten stuff, so peruse the list below and feel free to ask questions.
*RTT can be included for the right price, as well as the Midland MXT275 radio w/ 3dB ghost antenna
**First couple pics are from a trip. Traction boards, Rotopax and mounts, and shovel mount can be included for the right price.
*** Airbag dash light is on as I have a Scheel Mann seat installed with no airbag. Factory seat with Wet Okole cover will be installed for buyer. Scheel Mann is available for additional cost.
All the following have been replaced with genuine Toyota parts unless noted:
- LBJs, LCAs, and new cam bolts at 254,956
- Left rear axle at 258,770
- All four window belts, front and rear window trim
- NGK spark plugs with MSD coil packs 263,504
- TIMING BELT, water pump, fan clutch, radiator cap, radiator hoses, timing belt tensioner replaced at 263,515
- Power steering pump, and drive belt idler replaced at 268,058
- Both rear door checks 271,518
- Denso left rear O2 sensor 271,518
Mods/upgrades totalling over $18,000 (no that doesn’t include labor, shipping, etc.)
- Optima Yellow Top AGM battery purchased 12/2022
- OME Nitrochargers; 90004/2888 fronts, 60071L/2860 rears
- SPC UCAs
- Energy Suspension steering rack bushings
- CVJ Reman high angle axles
- SuspensionMaxx front swaybar endlinks
- Overland Custom Design rear swaybar endlinks
- GX460 front brake upgrade (bigger rotors and calipers)
- Crown Performance extended stainless braided brake lines
- Sherpa Equipment Co Belford rack with RTT mounts and traction board mounts
- Brute Force rear bumper w/ table
- Brute Force weld-on sliders
- Coastal Off Road front bumper
- Warn VR Evo 10-S winch
- Fuel D666 Shok bronze wheels x5
- 4x 285/70/17 Pirelli All Terrain Plus tires with matching, used, spare
- Auxbeam RGB 8-switch panel
- Auxbeam 3” 80W driving lights
- Baja Designs 3” SAE Squadron fog lights
- Nomad Morimoto converted LED headlights
- Black corner lights
- LED tail and turn signals
- Diode Dynamics SmartTap LED Flasher
- Vinyl flooring
- Kenwood DMX1037S heat unit w/ Apple CarPlay
- Ventshades
- Full Rhino Lining professionally applied over the entire body sans bumpers/sliders
- AirLift bags and compressor with remote
- Notorious tailgate handle/cable replaced with direct lever
- Wet Okole seat covers
- Secondary Air bypassed
- Eimkeith PCK
- Total Chaos spindle reinforcements
- 12oClockLabs SpeedoDRD
- Dash mount, electrical panel, and compressor mount from Kam Design Studios
- SPC UCAs
- Vinyl flooring
- Ventshades
- Eimkeith PCK
