SOLD: 110AH LiFePO4 battery & case (Houston, TX) pickup only
superg
I have a Valence U24-12XP (12.8V) battery & case for sale. This is a LiFePO4 battery. Used but very well taken care of and capacity is still around 100% of rated (see voltage pic fully charged). It has never been pushed below 20% discharge. Still has thousands of cycles left (100% to 0% as 1 cycle). Previously used to power National Luna fridge while camping but I hardly go and also have another bigger pack which ends up the one connected. This one has been delegated to airing up tires at home. I like to horde things I like so instead of just buying 1, I ended up with 4 sep LiFePO4 batteries so slowly selling them in the new year.
Please do not compare this battery to one in a Goal Zero. This is better chemistry, last 4-5x longer and is higher voltage vs what Goal Zero provides. The GZ does look nice :)
Price: $550
Specs:
110 Amp Hour (over 1400 watt hours at 12.8 volts)
Case is included if you want. Fits perfectly and available space for an inverter (I had a 350w Samlex PSW in that empty space).
Pickup only in the Houston area. Can also deliver to Austin/DFW etc since I do daytrips often to these cities.
Petersmithinak
