SOLD. - 1985 1st gen 4Runner - $22k
v8turbo
Sold.
Ready for its next adventure !
If you are looking - you know and understand the time and money invested and how much of a deal this Gen 1 4Runner is.
1100 street miles on vehicle since full rebuild less than one year ago. Truck has not seen dirt yet. Blah Blah Blah - So I need to sell. Clear Colorado Title. Passes Emissions by a mile. Located in Denver.
SR5, Sunroof, rear heater, power windows, AC, inclinometer, LED Internal lights, LED headlights, Rear Warn power plug for rear winch or jumper cables, Blue Sea power interrupt switch for rear power.
This is not a SEMA build for the show, I built it to last forever. The final stage would be to paint, but I like the patina finish and the millenials think its cool. Front seats are great and have always been covered. Rear seats were covered since new, So I added new Wet Okole Seat covers and new seat belts. Dash has a crack, Door panel is next on my list, it's a bit loose. Misc interior blems..etc. But it will run......
Full Drivetrain Replacement with all new parts. 22RE Performance, Marlin Crawler, ARB, WARN, OEM Toyota, TRD, RCV, Hella, Trail Gear, AllPro, Optima, Blue Sea, Factor55, Wet Okole, Rigid Industries, Old Man Emu, ...etc. Only the best used.
Items Replaced/New - Motor, Cooling System(OEM Radiator), Charging System, Starter, Updated AC, Suspension, Brakes, Steering, Exhaust/Muffler,Catalytic Converter, Bumpers, Winch, Lights, Axles, Differentials, drive shafts, transmission, transfer case, Wheels, Tires, Side Rails, Horn, every gasket, hose, belt, OEM Bolts, Etc....
Professional installation by a master Toyota tech that does the motor installs for 22RE Performance in Chico California. I shipped the 4Runner to Chico for all mechanical work.
-22RE Performance - I asked Jim to build the motor to last a lifetime. I said - Don't even ask, just add every upgrade available. Everything new. The best valves, Pistons, Injectors, balanced, blueprinted...etc. The motor is so smooth and revs very nicely. Professionally broken in before I even shipped it back.
NEW PARTS:
-Marlin Crawler - HD 5 speed with Marlins short shifter kit.
-Marlin Crawler - HD Transfer Case. 4.71 low upgrade
-Marlin Crawler - V6 front calipers, Rotors
-Marlin Crawler - V6 1.5 Bore Master Brake Cylinder
-Marlin Crawler - High Steer with 25MM Pin UPG
-Marlin Crawler - 4.88 Ring and Pinion
-OEM Toyota Dual Diaphragm Brake Booster
-OEM - Alternator
-Old Man Emu 2.5" Suspension kit/Shocks
-Wheelers Off Road Super Bump/Bump Stops on front
-Warn M8000S - Factor 55 Prolink/Offset Fairlead
-ARB - Deluxe Winch Bumper
-Trail Gear Rear Bumper
-All Pro - Sliders
-Offgrid Engineering Custom Dual Battery System - In cab Switch
-Optima Yellow Top Batteries
-Low Range Off Road battery- Box Powder Coated
-TRD - OEM TRD Pro Wheels
-BFG- KM2
-Blue Sea - Below Deck Panel in Rear for USB/Cig power
-Blue Sea - Fuse block for individual fused accessories, dedicated power interrupt, Rear Switch interrupt for Warn Plug
-Spider Trax - Toyota Wheel Spacers
-RCV - Front Axles
-Rigid Industries - LED Headlights, 2 Aux - Dually Side Shooter's
---Much Much more of OEM parts, OEM bolts, OEM plastic pieces.....etc.
I am sure I missed a lot - but you get the idea.
Pics -
