SOLD - 1991 Mitsubishi Montero LS for sale - Lots of service history and recent maintenance - Southern California
ChrisCosta416
Up for sale is my 1991 Mitsubishi Montero. I picked this up late last year and had fun restoring it!
This is ready for any 4wd Safari trip you want to go in! Tires are in good shape with lots of tread left and have the great Discount Tire warranty, 4wd works great! I would not hesitate to drive it across the country!
Located in Los Angeles - CA
Price - $9,000 (open to offers in person only - price is very negotiable)
1991 Mitsubishi Montero V6 LWB - LS - VIN JA4GJ51S7MJ007286
Automatic Transmission
3.0 V6
4WD with high and low range
Driver suspension bouncy seat
Limited Slip differential
225,101 miles
Clean title and will smog before selling
Engine rebuild at 185,XXX miles with photos, receipts and more
Additional repair and parts receipts since 2008
Redone headliner
Maintenance done since my ownership
  • New Aisin Timing belt and water pump
  • OEM Tensioner and tensioner spring
  • New OEM crank bolt and washer
  • New OEM Front camshaft seals
  • New OEM Front Crankshaft Seals
  • New OEM Crankshaft sprocket flange
  • New OEM Thermostat
  • New OEM radiator cap
  • Rodded out OEM radiator
  • New OEM radiator hoses and hose clamps
  • New idler arm
  • New MOOG lower ball joints
  • New MOOG inner/outer tie rods
  • New Hyundai Galloper wipe arms (front) with Denso wiper blades all around
  • New KYB Shocks all around
  • New Powerstop rotors and pads all the way around
  • New Denso AC Compressor
  • New AC expansion valve
  • New Denso Receiver Drier
  • New OEM quarter window seals
  • AC has been converted from R12 to R134 with the parts listed above
  • New windshield washer motor pump
  • Gen1 Steering wheel replaced with earlier gen1 steering wheel with horn buttons
  • Transmission serviced with OEM Mitsubishi SPIII fluid
  • Fresh oil change
Parts included with sale
  • OEM Radio bezel
  • Aftermarket radio with harness
  • OEM Mitsubishi Wheel lock
  • OEM Mitsubishi Jack
  • Spare parts
Some not so great things with the truck
  • Heater core is leaking so we capped it off and bypassed the heater core
  • Radio wire harness is cut (I have a new aftermarket radio and a harness to splice, just don’t have time to do it)
  • Rust on 2 spots, Fender and Rocker panel. There is no other rust on the frame. Feel free to see it, I have provided photos
  • Oil seeping around engine oil pan
  • Steering wheel column cover missing
zhukoveli
